1 kicker solo x 15
It should do fine man. Id recommend this setup for the money.I have two of these amplifiers and they are great for the $coin. The Hawk 15s Slamm! Id recommend the GP XL ported Glue and screw enclosure tuned to 31 HTZ double baffle
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
787
Carlos1son
CarAudio.com Regular
Carlos1son
old bridge NJ
Carlos1son
    May 31, 2024
    May 24, 2024
