4th order for Type R 12 d2
  • 1
Jroo
I have a type r 12 sitting around that I received cheap. I was told these are 4th order friendly and had kicked around the idea of building one since I am sitting on the sub. I saw plans recently for a sealed side of 09 (cu. ft) and ported side of 1.0 (cu.ft.) with a 4 inch port tuned to 50hz. I was wondering what the general performance of that plan would be? The last 4th order I had was similar ported and sealed sections but the tuning was higher like 60hz. The plans were made with a 1 to 1 ratio and higher tuning to get bandwidth from 70 down to 30 if I remember correctly.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
836
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
7
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
Jroo
Jroo
richmond virginia
Jroo
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
