6.5" speaker location, '06 BMW M5
  • 1
  • Participants list
M3Gonz
CarAudio.com Newbie
Hi all,
I'm embarking on an audio build on this vehicle, SQ is my primary purpose. This vehicle features 4" speakers in both sets of doors and the rear deck, as well as tweeters in the front doors and rear deck, then 8" factory subs under each front seat. While doing some research I found an interesting option that one installer used, he removed the factory subs from under the front seats, then put the 6.5" speaker from a 3-way component system in the underseat location with a bracket to make it fit the opening. An enclosure for most likely a single or double 10" sub will be built in the trunk.
What are your thoughts on using the underseat location for front of car 3-way component speakers. Speakers currently in consideration would be Morel Virtus or Elate 3-way featuring a 6.5, 3.5 and tweeter. Also looking at Focal. Other options, opinions or suggestions welcome.
Thanks!
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
596
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
634
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
6
449
M3Gonz
CarAudio.com Newbie
M3Gonz
St. Paul, MN
M3Gonz
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
Latest topics
