Audio connection in Pasadena
  • 3
  • Participants list
denim
SSAudio.com
33,767
158
SSA HQ East
{Let me preface this saying that have run/managed & installed at two different audio shops in the past, and have 20 years experience in car audio, let alone own an American made speaker brand.}
Look else where immediately. Disorganization and incompetence at it's finest. The manager does not even understand the simple principles in speaker or sub woofer design or enclosure build. Took three months to get one response to a number of texts and email messages, only to be told it will be another 2.5 months before having a window of time to work on my car.
They don't even have 1/0 power cable in the building. You cannot, in good conscious, hand your car over to a shop who is run by someone that believes cone size, in modern sub woofers has an effect on overall frequency response. Or that thinks, let alone utters the words, "a 10" hits higher then an 18" and 18" subs are sloppy", not to mention thinking that the L7 is the end all.
In regards to an Icon 18" demo we loaned them out, they snapped three screw heads off in the basket mounting holes, scratched the basket to ****, built a poorly constructed sealed box for the sub, black marks and scratches all over back plate.
I'm stunned that they think they are able to have quality performing installs with this level of knowledge. Wow, very upsetting. If you value the performance from your audio system, this is clearly not the place.
What a ******* lol
---------- Post added at 06:22 PM ---------- Previous post was at 06:22 PM ----------
Why should they worry about your system when they have lines out the door for "Blow-N-Go?" I never had experience with Glen Burnie other than walked in to ask about a headunit that was innstalled at Towson and the guy basically slammed the installer till I toldhim it was 1 of there stores and they were able to do the warrnty work or basically fix the F up
Sounds expected. They should care about my install as it was larger and more money that I had in hand. Not a window shopper, in addition to the exposure. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
97
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
547
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
611
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
denim
SSAudio.com
denim
SSA HQ East
denim
Doxquzme
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
Latest topics
