Best Canon Video Converter-Import Canon PowerShot MVI/MOV to Pinnacle editing
Good News! Pavtube Time Limited for 2011 Thanksgiving Day! Only TWO WEEK! End up on 5th Dec!
The PowerShot products are a line of consumer and prosumer grade digital cameras, launched by Canon in 1995. The PowerShot line has been successful for Canon, and is one of the best-selling digital camera lines worldwide.
The newest is PowerShot SX210 IS. Users can capture quality HD video on demand, thanks to a dedicated movie record button that allows them to immediately start shooting movies, even if the camera is not set to Movie mode.
720p HD footage is recorded at 30 frames per second, with stereo sound included to provide high quality audio, while the quiet 14x zoom lens offers the capacity to zoom close up to subjects that would normally be out of the reach.
For smooth movie capture, the PowerShot SX210 IS also features a new Dynamic Image Stabilizer. A technology inherited from Canon video cameras, Dynamic IS further reduces the shake caused by a user's movement, such as walking. When movies have been captured, the integrated HDMI mini connection offers a lossless way to share video – and images – on HDMI-compatible devices including HDTV screens.
Canon PowerShot users will find the recording vdieo files are MVI.MOV format.
How to convert Canon PowerShot MVI,MOV files to AVI,MPG ect?
Step 1. Load H.264 MVI,.mov files to Pavtube Canon Camera Video Converter.
Transfer h.264 encoded MVI .mov files from Canon PowerShot Camera to computer via USB cable. Run this Canon MVI/MOV Video Converter , and click the "Add" button to load MVI .mov videos.
Step 2. Set AVI/WMV/MPG as output format for editing.
Click "Format" bar to determine output format. Follow "Common Video" and select any format from "AVI MSMPEG4-V3 (*.avi)", "WMV3 (WMV9)(*.wmv)" and "WMV2 (WMV8)(*.wmv)".
Step 3. Adjust video and audio settings to optimize output file quality.
Click "Settings" button, then you will be able to adjust audio and video parameters on the popup window to customize the output file quality, these adjustable parameters include codec name, aspect ratio, bit rate, frame rate, sample rate, and audio channel. To maintain original HD quality, you may set "original" in the fields of "Size", "Bitrate" and "Frame rate". To downsize the Canon PowerShot MVI.mov files, just set a smaller bitrate.
Step 4. Click "Convert" button to convert Canon PowerShot MVI.MOV files to HD AVI/WMV.
Once the conversion is finished, you can click "Open" button to get the output files effortlessly. Now you have got it right, just to import and edit Canon MOV files with Pinnacle and other editing software for editing.
Additional editing features of the Pavtube Canon Camera Video Converter:
Combine files together- check the files to be merged in file list and check 'Merge into one' box beside 'Settings' button.
Deinterlace- click 'Editor', switch to 'Effect' tab, find 'Deinterlacing' box, and check it to eliminate interlacing lines.
Thumbnail- click 'Snapshoot' button when previewing the video. Click 'Option' to set the image format of screenshots.
Trim a section of the movie- click 'Editor', switch to 'Trim' tab, and input time point in start and end box
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
583
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
881
JohnnyEdwards
Los Angeles
>>SQL<<
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
