B'ham Install
there's some folks on here from up that way. see if you can find them and get them to help you. usually shops will put it in your butt //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I'm planning on having a BBQ next Spring. Trying to get a lot of the DIY guys there so we can finally meet in person.
What kind of setup are you running?
Im actaully in the midst of building my 350z. As of now i have my TC OEM10 in a .6uft enclosure. Still deciding on amps but im pretty set on the alpine pdx amps. I would love to meet some other car audio diy'ers.
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
748
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
4
942
southernhonda
southernhonda
B'ham,Al
PaulD
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
