Car Audio Terms defined
thanks for all the definitions, not that anyone cares but I copied and pasted that to word and it's 50 pages :thumbsupw //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
as far as bandwidth goes ..... it pulls about as much as a regular post, not even close to an image size .... roughly 1/5th the size of a single regular image depending on varying factors
Great list. You forgot Crossover slope:
The crossover slope describes how sharply or quickly the crossover attenuates (decreases) the amplitude (strength) of audio signals at frequencies above (low pass crossovers) or below (high pass crossovers) the crossover frequency. The slope is described in dB per octave. The higher the value, the sharper the roll-off, and the more control the listener will have over which frequencies are played by any particular speaker. A 24dB/octave slope is considered very steep (good) and a 6dB/octave slope is relative low (more difficult to control audio signals).
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
113
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
What he's saying is you need to pull the head unit out of the dash. Leave it connected to play, pull the speakers out of the door, and the wire...
6
711
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
KARLEON
Livin' Legend
KARLEON
Chattanooga, TN
JohnC005
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
Latest topics
