Cascade APS-30 power supply
  • 1
  • Participants list
Jcsaudio
//content.invisioncic.com/y282845/monthly_2019_03/30B2DFCB-614F-4633-A307-BC7601CE364B.jpeg.695cdb2070322287d209943ae8da4e8c.jpeg
View Listing
Product Brand & Model: #4 Cascade APS-30 power supplyCondition of all items: #4 Cascade APS-30 power supply used 7/10 cosmeticallyTotal Price: :
#4 Cascade APS-30 power supply $[SIZE=13.333333015441895px]95 [/SIZE]shippedShipping Terms: :On meAdditional info:
The Cascade power supply is handy to have for tuning and or shop owners who struggle with batteries going dead while tuning. You can use this to power your vehicle and charge the battery and it won’t over charge the battery because the voltage is 13.6 volts and the amperage adjusts down to just millvolts as the load demands decrease. It’s a nice tuning tool to have. It also doubles as a battery charger and can be wired in series with up to 4 more APS 30 power supplies for increased amperage. You can install the included jumper for 14.2 Volts when more power is needed but you have to be careful if using a battery not to overcharge it.
http://www.cascadeaudio.com/power_converters/power_converters.htm
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
140
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
146
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
444
With 6500 rms.. you are still going to need some battery bank and/or supply for that demand
15
Jcsaudio
Jcsaudio
Worcester, MA
Jcsaudio
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
Latest topics
