Extreme Audio
  • 5
Trey803
GAMECOCKS
5,949
SC
If you ever get the chance to go here please dont. There prices are out the roof installation takes up to two days and they screwed a ground wire down with a metal screw into the bottom of my freinds truck.//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
No comment on the time frame for installs but I don't guess I see the problem with what I have bolded. If there wasn't a sufficient ground point already available how do you recommend they should have proceeded?
Shoot- my main ground is welded to the spot it is attached to!
how else would they do it?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
so....they grounded with a screw to the cars body.....
and that's a bad thing?
then you wouldn't like our shop (Circuit City in Augusta) cause we scrape the metal bare and THEN screw it down with a screw...lol
i think what this man is saying is they took a screw and just screwed into his floor when there were many places to ground it without creating a random ass hole in his truck.
I would assume it is the radio's built in eq curves that are meant to protect the OEM speakers. You will need a DSP with signal leveler. That...
5
933
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
234
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
643
Trey803
GAMECOCKS
Trey803
SC
budahbuddy803
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
