For Sale Brand New QSC K12.2 K.2 Series 12" 2-Way 2000 Watt Powered Speaker
bigstocks
CarAudio.com Newbie
Jun 15, 2019
10
-7
Configuration    Multi-purpose, 2-way powered loudspeaker
Transducers    LF Transducer: 10" / 254 mm, cone
HF Transducer: 1.4" / 35.6 mm titanium diaphragm compression driver
Frequency Response    Frequency Response (-6 dB): 56 Hz - 20 kHz
Frequency Range    Frequency Range (-10 dB): 50 Hz - 20 kHz
Nominal Coverage Angle    90° Axisymetric
Maximum SPL    130 dB @ 1 M, peak 124 dB @ 1 M, continuous
Amplifier    Class-D
Peak: 1800 W (LF), 225 W (HF)
Cooling    Low-noise, variable speed fan
Controls    Power switch
Level Dial: 3
Rotary encoder (push)
Selection Buttons: 2
Indicators    Monochrome LCD Display 1.8 x 1.0" / 45.0 x 25.4 mm
Power LED (Front and Rear): 2
Input Signal LED: 3
Input A Mic selected LED
Input B Hi-Z selected LED
Limiter active LED
Connectors    Mic/Line Input and Hi-Z/Line Input: 2 x locking XLR/F 1/4" / 6.35 mm combo
Stereo Input: 1 x 1/8" / 3.5 mm TRS
Loop-Thru Output: 2 x XLR/M
Mix Output: 1 x XLR/M
Power Connector: 1 x locking IEC connector
Power    AC Power Input: Universal power supply 100 - 240 VAC, 50 - 60 Hz
AC Power Consumption (1/8th Power): 100 VAC, 2.1 A / 120 VAC, 1.9 A / 240 VAC, 1.1 A
Enclosure Characteristics    Enclosure: Impact resistant ABS
Attachment Points: 2 x M10 threaded inserts plus pull-back
Color: Black (RAL 9011)
Grille: 18 Gauge powered coated steel, internal cloth lining
Regulation Compliance    CE, WEEE, UL, China RoHS, RoHS II, FCC Class B
Dimensions (H x W x D)    20.4 x 12.6 x 11.8" / 518.2 x 320.0 x 299.7 mm
Weight    32.0 lb / 14.5 kg
Packaging Info
Package Weight    38.8 lb
Box Dimensions (LxWxH)    22.0 x 17.5 x 16.5"
For order placement and more information kindly contact us through the following below.
E-mail : [email protected]
