Breakdancin11 10+ year member
What if I took out the rear fill speakers then cut out some ports on the same plane of the rear fill speakers?
-Jp
-Jp
you could remove the rear glove box and cut the sheet metal out underneath it, then attach the lid with velcro if you want to cover it up. still not the same as the sheet metal //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifWhat if I took out the rear fill speakers then cut out some ports on the same plane of the rear fill speakers?
-Jp
alot of bass to the human ear //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif if your gonna cut behind the armrest, you might as well remove that whole section...take your seat out and you will see what i am talking about. then you remove that plastic panel behind the armrest and keep it folded down...difference is night and day.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Thats exactly what I was thinking. Now if I were to do this would I be gaining more then just a .5 decible? What about cutting a hole where the armrest is?
If the sub is rear firing will this cause any problems or will I have to switch the way they are firing? Also, will their be a good increase in the bass to the human ears if I were to do some cutting, seeing as thats what I really want.
-Jp
Ok so if I were to take out the rear speakers AND cut the piece out of the back of the Caddy it will be louder then maybe just taking out the rear speakers. You have me almost talked into taking out that panel. You said that I may as well take out the rest of the panel if I were going to cut for the armrest. So there would be a difference from a small hole cut and the armrest down and a big hole cut with the armrest down. Also how big is the piece you would have to cut for this big cut......the picture you should me was HUGE.alot of bass to the human ear //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif if your gonna cut behind the armrest, you might as well remove that whole section...take your seat out and you will see what i am talking about. then you remove that plastic panel behind the armrest and keep it folded down...difference is night and day.
i took alot of material out, you don't have to remove that much. if you remove the seat, you'll see an indentation, you can't miss it. probably about 15"x30"Ok so if I were to take out the rear speakers AND cut the piece out of the back of the Caddy it will be louder then maybe just taking out the rear speakers. You have me almost talked into taking out that panel. You said that I may as well take out the rest of the panel if I were going to cut for the armrest. So there would be a difference from a small hole cut and the armrest down and a big hole cut with the armrest down. Also how big is the piece you would have to cut for this big cut......the picture you should me was HUGE.
I appreciate all the help your swinging my way
-Jp
nah. when you remove the seat, the armrest will come with it. just take the plastic insert out. then drill a hole in the sheet metal and cut out your desired area with a jig saw or sawzall.I am to do some cutting and see if I am satisfied with just cutting out the spot where the armrest goes as well as removing the rear speakers. Maybe this will cure my need for more bass for the time being heh. Any problems I may run into while cutting the spot for the armrest?
-Jp
Does anybody have any experience with smaller cars? I have a 95 grand am (2door) and was thinking of facing the box forward for competitions. Now would I be better off pushing the box right up against the rear seat area or pushing it towards the rear but the sub still facing the front? The rear speakers were removed by the way...
