help 4 Multi project for my 02 Qx4. Audio/exterior/interior/ect. Philly/South Jersey
  • 1
itsjussed
Whats up guys. I been lurking a while and I finally got all my stuff together to install. I am looking for someone/people too help me with the followings things. also if you can do custom work for a good price, let me know also.
exterior
-installing replacement bulbs
-custom headlights (led strip, make clear corners, restoration, custom, ect)
-tint the tail lights or customize
-touchup paint in problem areas and chipped spots.
-customize the grill for the qx4
-redo/paint the trim (window trim, bumper trim, wipers, running board)
-undercoat/fix the rust at the bottom/caliper/muffler
-paint my wheels (stock qx4 wheels need to be primed, painted, clearcoat ect)
interior
-Replace lights in interior (dome, map , gauge, behind the ac/heater, door button lights)
-remove seats to clean all pet hair in most crevices
-protect trim and leather seatings
Audio
-install a set of mb quart pvi216 component speakers (mount or possibly create a custom job to hold the crossovers and amp)
-install and mount a mb quart dsc 4125 amp (mount or possibly create a custom job to hold the crossovers and amp)
-install a headunit and a backup camera in the trunk key hole.
i will have pretty much all the products and items. i just need labor and a semi mentor to teach me.
you can PM me or email me at itsjussed@gmail.com with your info, offer, and price for the job. let me know if you guys know of anyone in the south jersey area or Philadelphia. i can drive. thanks
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
133
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
171
11
376
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
250
itsjussed
itsjussed
Philly/AC
itsjussed
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
