Is line level ok to feed to an Aux jack?
  • 1
Phil12345
CarAudio.com Newbie
Ok so here is my plan i have an 07 jeep compass with the stock head unit and speakers. I recently pulled the same speakers and head unit out of another car and made it into a removable boom box type of thing that would sit in the back of my jeep. What i was wondering is if i used a line level converter to tap into the existing speakers could i then go from that to the Aux input of the second head unit to feed the boom box from the car when plugged in. Essentially feeding one radio from the other and using the second radio as a cheep amp that also can be used as a AM/FM/CD player when taken out of the car.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
The preamp input on most amps is 10-20k ohms, so you don't really lose voltage. I've run plenty of systems off 2v preamps with no problems.
5
912
Phil12345
CarAudio.com Newbie
Phil12345
Phil12345
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
