Just a few sub recommendations and box questions
noidea
CarAudio.com Newbie
Number of subs preferred: 1
Size preferred (if configuration allows): 12”
Budget: Best bang for buck but say up to $200-$300 if required
Power to be used (which amp(s), include which resistance): Pioneer GM D9604  https://pioneer-mea.com/en/products/gm-d9604/
Space available (take measurements, do not guess): As little as possible! Please see more below
Goals: Good blend of loud thumping bass and decent SQ
Listening habits: Mostly house music and rap music
Preferred brands/subs/whatever: Open to ideas however I had been looking at the following so far (for no real reason aside from online reviewes) Rokford Rosgate P3D4 and the Focal P30F
https://rockfordfosgate.com/products/details/p3d4-12/
https://www.focal.com/en/car-audio/car-audio-kits-solutions/performance/expert/subwoofers-bass-enclosures/p-30-f
Now, I have the following questions..
1.    Are both of these good matches for the amp using channel 3&4 bridged to power the sub?
[SIZE=11pt]2.       [/SIZE]With regards to the enclosure, I’ll be getting someone else to build it, but how does it work?
[SIZE=11pt]a.       [/SIZE]Both online spec sheets say I’ll need around 29/30L, is that pretty much it, or can someone using software determine what size it really needs to be?  (Ideally I’d like it to take up less room if possible)
[SIZE=11pt]b.      [/SIZE]I’ve heard of ppl using software which then says that the ideal size would be say 15L as an example.  Why would software say that when the spec sheet says 29/30L for a sealed enclosure?
[SIZE=11pt]3.       [/SIZE]Any other recommendations that are better suited to the amp that are worth considering?
Thank you all!
1) you need to get a dual 2 ohm or single 4 ohm sub to run on that amp correctly since it wants a 4 ohm load.
2) Yes there is enclosure design software out there. Generally speaking though the enclosure tend to be larger when using that software. the manufacturers will suggest enclosures that satisfy the majority of the people looking to purchase their gear. Which for a lot of them smaller is better.
we usually overpower subs because of box rise.. to most of us 2 channels of that amp wouldn't be enough power for a 12 but yeah it'll work.. like he said if u bridge 2 channels u need either a d2 sub or single vc
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
958
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
975
Different subs on Different amps in a shared airspace won't be good
69
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
4
129
noidea
CarAudio.com Newbie
noidea
THATpurpleKUSH
Doxquzme
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
Latest topics
