need a tampa/brandon installer thats not outrages
Quick drive to louisiana and we will knock it out. Crash a night and go home bumping.. Prob be cheaper then a shop as gas is not that much compared to 150 to intall a single amp.... Bahhhh takes 5 mins
Shops are good if u want a pure show car " even some shops **** at this" They overcharge and some not all do subpar work especially if you did not buy equimpent from them. Audioedge "louisiana" wanted almost 200 bucks to install from comp set LOL... That and my flutes and seas are junk and I need better ones I walked away fast and said good luck with your sweet alpine setups...
parts need include dash kit 99-7872 ( that one is pricey because the a/c controls are in the bezel )
harness 70-1722 (4 or 6 speaker system)
ant adapter 40-hd10
that's all the parts needed (part #'s are all metra) most shops as well as best buy carry metra
dash kit should be any where from $45-$60 harness $15-$20 ant adapter $10-$15 plus labor so $70-$95 in parts and $35-$50n in labor
so $105-$145 ish dont pay more good luck
parts need include dash kit 99-7872 ( that one is pricey because the a/c controls are in the bezel )harness 70-1722 (4 or 6 speaker system)
ant adapter 40-hd10
This is confusing I have all the parts already, so what do u think labor should be for 4 speakers a amp a hu and a sub w amp install
ant adapter 40-hd10
that was for the h/u install
as far as the other stuff // 4 speakers $100-$175 /// amp install is dependent upon ift you have the amp kit or not // if not a "good" 4 gauge kit installed should run $250-$325 (upper end being ofc) // subs will also depend on what you mean by "installing" them // if you mean just screwing them in to your box that should be free ... but if a box needs to be built or modified= more $$$
your 1st post said nothing about having all the parts // most customer do not have all their own dash kits etc... (especially a premium kit)
looking for a installer that does good work I want speakers deck subs and amp installed in a 08 honda fit.
so please provide more info like exactly what you do and do not have // deck?// amp?// subs?// box?// amp kit (power wire, ground wire, rca's, remote wire, fuse holder)?// dash kit?//wire harness?//antenna adapter?// door speakers?//
so basically b-4 you can get a more accurate answer to you question it will need to be posed a little more succinctly
if you have everything required and not looking for a shop 150ish for 4 speakers h/u amp sub.. now then if you have a 4 channel for the speakers you get into more work etc.. also depending who does it if they do it right and run new speaker wire not stock then that will cost more..
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
379
11
378
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
mdsniper7
mdsniper7
tampa fl
KyleBechtold
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
