Southeast Region Orlando, FL Recommendations?
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
  • 3
venoxcide
US
Hi all,
I have a 2014 Ford Fusion SE that I'm looking to do an install on.
I'm in Orlando, FL and am looking around to find a good shop with a reasonable price.
I have all the equipment already taken from my previous car, which I've installed myself but because this car is newer and I'll be integrating into the factory radio, I'd rather have it done by someone with more experience.
What I need to be installed:
|- AudioControl LC2i
|- 4x Kicker KS 6.5" Coaxials
|- Run new 16GA wire for speakers to multichannel amp.
|- Run power/ground for two amplifiers.
Physically installing/tuning the amplifiers and subwoofers I can do myself. I basically just need all the wiring done and the door speakers installed as well as have the LC2i installed somewhere where it's accessible.
I had a shop called On Point Audio quote me around $700 for this, I'm not sure if thats a reasonable price.
Any general advice/tips is also welcome!
EDIT: I Realize this post is in the wrong section, apologies!
I just got quoted $600 from another place and the told me that most of the money is for running the new speaker wire, so I'm guessing most places would be around the same?
Sounds like it. Your doing the right thing...just keep calling diff places getting quotes.
Just a thought: Wonder if it would be cheaper if you supplied the speaker wire than if they did.....might knock down the price a bit. Oh wait...just read the 1st post and if you don't have some sort of power/ground wiring for the amps, more than likely they will supply it and charge you for it.
I do have power/ground. I'd rather use something that I know is proper true gauge and OFC than have them use some cheap amp kit with CCA.
And good idea, I will ask if it's cheaper if I supply my own speaker wire! Thanks.
Been to Orlando a few times....some people just can't take the heat/humidity there. International Dr and Kirkman Rd sure is a busy area!!
Oh dam..... your really close to Universal Studios. Huge place too...been there 2 times and still haven't seen everything.
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
12
213
Doors and dash? Year, make and model of the car? Amplification? Midranges or coaxials? Need some more specifics about what if anything is already...
304
Heck...done right...you could get an amazing sounding stereo using $15-25 drivers from partsexpress 😂
9
568
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
I read your post and thought about all the aftermarket decks that were installed using the factory power wire. This is why manufacturers quit...
92
5K
venoxcide
venoxcide
US
LosIsATool
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
