Will a High Output Alternator Fry my car's Electrical System?
i have nissan maxima 2000engine:VQ30DE
i need ~400 amp alternator for my car
what do you recommend me??
plz help me!
you'll be hardpressed to find someone who can even build a 400amp alternator for that particular vehicle....
what does your system consist of that draws this much amperes???
your best bet is to run a dual 250amp alternator setup with custom brackets... if thats even possible
You fuse for the wire, Correct? If you have a HO alt that puts out around 200 amps peak than you should use a wire capable of that and then some this is were 0 gauge comes in. So you would fuse for the 0 gauge cable, which can handle 300 amps, well over the maximum that the alt will put out, and you use say a 250-300 amp fuse. The fuse is not their to stop the device from drawing or putting out so much current, its to stop the circuit in the event of a short. Am I wrong?
all i have to say is that alternators can and will fry your car.. i had a brand new chrsyler 300M just put 2 JL 13W7, and 2 JL 1000/1, and a JL 300/4 in there had a HO alternator put in was a 200amp.. have a 1/0 gauge from the alterator to the battery... and this is what happened to my car when i got two miles down the road after having all the work done....
I look at this pic and it is like a "wheres waldo" pic
soon as i saw it i seen the problem... look where the fuse is mounted, on the back where you normally put the alarm sirein,, way further from the battery then the 18 inches max that all installers go by. The whole reason for that fuse is to pop when there is a short so it dont heat up and start a fire,, there looks to be about 3 feet of wire from the fuse to the battery. now with that i am sure there was a short in the 3 feet that wasnt fused,, which got hot, REAL HOT caught fire and well... you know the rest... IT WAS NOT THE ALTERNATOR IT WAS A SHORT IN THE MAIN AMP WIRE FROM THE BATTERY! The pic shows you right there you see the fuse and you see the red insulation on both sides then you see the thick copper with the insulation melter off in the middle fo the fire well there is where your short was.
Ha do realize that people on the internet will argue until the end of time so... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Steve Meade has what I believe three Ho alternators and he beats that **** all day long. Alma Gates' Bronco had 11 custom HO alternators and her truck didn't explode, and 99% of the people in this car audio hobby aren't even worthy enough to stand next to her.
Those two are good enough examples that HO alternators itself won't do a **** thing to your electrical system. A faulty install/hardware will.
Let me get this right... If you are drawing more current continuously than your alt can supply then your battery will go flat. If you sub amp is pulling peak current draws bigger than your Alt supplies then the battery supplies all the extra current. If you are pulling more current with peaks than your battery can supply you should upgrade your battery to handle the demand. If your electrical system is drawing continuously up to 80% of your Alts supply then you will need to look at replacing your Alt. A minimum 20% should be left to recharge the battery. So as I see it how does running more current on a stock Alt destroy it - I'm of the thought it will just run your batteries flat. I'm always hearing my stereo killed my Factory alt.
Please explain how in detail or support my thoughts that once it hits its regulatored limits thats it.
CHEERS
I'm more confused as to what to do now than I was previously.
Too many saying "do this", others saying "don't do that or this will happen".
Makes me want to go back to stock and **** it all.
Are there any experts? And not self proclaimed experts. I need my truck running not melting.
Coulda already had his answers (4) My interior dome lights are dimming with bass | DiyMobileAudio.com Car Stereo Forum
20
3K
I have not tried any Lith.Batteries yet. I am debating on that for Next years build out. deff considering
15
3K
Cat as in animal. I had it sitting out on in the box with the box open as I grabbing some connectors from the other room as it was on the one...
14
Bumpin' Yota
Bumpin' Yota
FL
Water Bear
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
