Wiring Help.
  • 2
toyjoha
This must just be like livin' in Paradise...
I just bought a car and this is what it came with so I am not looking to upgrade just to get the best, clear, loud sound that I can.
The amp is a Pyle (Bridgable)
Power Output: 1200 Watt MAX
4 x 150 Watts RMS @ 4 Ohm
4 x 300 Watts MAX @4 Ohm
4 x 300 Watts RMS @ 2 Ohm
The sub is Massive
700 RMS
1400 Peak
DVC 4 ohm
As of the way that I received it, it is hooked up on one channel (the other 3 empty) with (+) split and going to each DVC (+) and the (-) split and going to each DVC (-).
I am a newbie, but that does not sound right from what I have read. I was thinking of bridging 1 & 2 to one side and 3 &4 to the other, or I should bridge1 & 2 and run parallel DVC(+) to (+) and (-) to (-).
Or something else?
Not sure what model the amp is that you have but bridged most are only stable to 4 ohms. Running 2 channels bridges to once voice coil and the other 2 channels to the other voice coil wouldn't be a good idea unless you have a DMM, CC1, or DD1 meters to get the gains and crossovers to match perfectly.
Your best bet would be to get a mono block amp around 1200 rms at 2 ohms.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
340
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
771
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
866
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
toyjoha
toyjoha
Key West, FL
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
