Please help with powered sub settings.
  • 2
edweather
Had this Rockford Fosgate powered sub installed by a local installer. Not sure what the best settings would be. Concerned about all settings, especially the phase and auto turn on.
Is my audio input RCA or speaker level? I have a remote bass knob that plugs into the remote jack. I attached a few pics. Any help is greatly appreciated. Thanks.
You indicate it was installed? Why did the installer not go over the settings with you? They didn't set everything up?
What is the system?
Did you have this added to an OEM system?
If so, it should be setup already.
Not following the need here.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
edweather
edweather
Georgia
    Jul 2, 2024
AnthonyO
    Jun 30, 2024
