Use high and low level input simultaneously
  • 2
I have have a JBL GTO755.6 amp that I currently have connected to a pioneer deck through the pre-outs. I just installed a bluetooth hands free device in my car and would like to connect it to the amp as well. The amp has high level inputs that are not in use right now so I would like to use those for the hands free. Will I damage anything if I have both low and high level inputs in use and connected to different sources at the same time? Is there anything I should be aware of before I try this?
Thank you in advance.
Generally you are not supposed to use high level inputs and low at the same time on a car amp. Reason is simple. The power of the amp runs through one or the other. Using both will damage the amp because of the over exceeding draw from 2 devices vs one device.
Most install manuals that come with your amp will warn you not to use both inputs. The wired inputs are ONLY in case your head unit doesn't have RCA outputs. Best set up is using a amp for the sub and a separate 4 or 5 (etc) channel amp for the speakers. Adding a power conditioner is the final stage of a solid car audio system.
Generally you are not supposed to use high level inputs and low at the same time on a car amp. Reason is simple. The power of the amp runs through...
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
531
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
RickWagstaff
RickWagstaff
Aldergrove, BC, Canada
missionman
