Hehe..these are fun.
1. Open Glove box. You will find two screws in there. They are either 8mm or Phillips head.
Remove those.
2. Remove panel under the steering wheel. I believe there are three phillips heads
holding it on.
3. Under that you will find two phillips heads. Remove those.
4. Remove the panel under the radio. (is likely to contain a cigarette lighter. Unplug that.
5. Look under the radio where you just took the panel out. There are four ten millimeter
screws that hold the radio in. Remove those four and the whole assembly, radio, ac
controls and the whole sha-bang.
6. Be sure that you dont need to retain the factory radio for keyless entry purposes. Some
of those need it.
That should get you through the process. They kinda **** to do, but once you have done one, that aren't all that bad. If you have any more questions, feel free to ask. Just have patience, and use your head, and things should come out well for you.
