02 taurus head unit
  • 2
You need a special key to take it out. There are two of them and they are shaped like a U. You can get these just about anywhere..Wal mart, Autozone, etc..
You will need an aftermarket radio mounting kit. You can get one of these at a local audio shop or online.
Here is a link to the Kit you will need.
http://www.metraonline.com/product.aspx?sku=99-5716
The tuner pack is located on the drivers side rear fender. You have to run a wiring harness and antenna (included in the kit) from the tuner pack to the front of the car. Its not a hard install..Just kinda time consuming for a deck.
You will also need a wiring harness. http://www.metraonline.com/product.aspx?sku=70-5715
If you need any other help...Go ahead and ask.
I not around my truck right now but it's 99 f150 it that helps. It's not got alot of ventilation back there . I try to take doing my wiring...
314
6
730
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
939
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
949
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
jbove
jbove
grosse pointe, MI
crhye250r
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
