10" subs
Casper
Ok, I have a 2000 F-150. I am putting a dual 10" sealed box (that fits under the back seat) in very soon. The problem I have, is I am a sound newbie. I am going for pure SQ and I am really up in arms about what subs I should get. I am not trying to break the bank, but I don't want to go cheap either.
I am thinking about going with the mono 1500 W (1 ohm) hifonics sub because of reviews if that helps at all.
Sorry about the lack of info, but I am quite new at this.
Casper
casper, I just (this weekend) finished a project doing the same thing with my dodge ram. If you don't have a box yet be careful. I origionally bought one and it said it had a mounting depth of 5". I had some 10" subs and they had a mounting depth of 5". Come to find out that it isn't even close, I will send you pics if you want. I ended up lifting my back seat 3 1/2" and built my own box. I could fit 12"s in it if I wanted and it is 9" deep. Each side has .909 cubic feet of air so it actually has more air space than what it is supposed to have. Just wanted to throw a shout out to you about what to be careful of. My subs are audiobahn aw1000q and they are very spl type subs. Loud enough for me so you would want another direction than these for your sq. Good luck.
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
381
Aw.... You're talking about good ol' Mich.
15
743
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
476
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
Casper
Casper
N'awlins
slick rick
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
