10" XXX Numbers Please!
Which would be louder/better
  • Total voters
    6
Omarvelous
Queens, NY
Was wondering if any1 knows how loud this sub gets?
I'm thinking about going with 1 10" for now in a 2.0 cuft or more ported box.
Do you guys think I should get a 12 instead in a 3 cuft?
Reason why i'm going with the 10" s if i get a 10" , i'd have room for a 2nd later on.
So, what would u prefer, 2 10's Ported or 1 12" ported?And why?
I'd go with 2 10's just because it's louder....
depends on whether or not he has the money or the electical system for an amp that is powerful enough to run both, or 1 amp per 10. if i had the money and the power supply i would get 2 10's.
al
My Amp Choices will be either
36.1 for each,
or Visonik V900HC which give out 3200 at 1ohm.
But not sure bout the visonik amps, been hearing bad things.
Also was thinking an Orion2400, i think they put out 2400
Anyone know of any other amps that put out 2000+. Will do a search now. but TIA
I'm not sure if it was mentioned, but you can removed all bass absorbing material from the inside, such as carpet and cushioned seats. Also, do...
16
4K
Omarvelous
Omarvelous
Queens, NY
Omarvelous
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
