12w6 and PC2600??
substance
houston
I have a PPI PC2600, and my friends giving me 2 JL 12w6's (older models) for my old kenwood amp. i was wondering if i should hook just one of these subs up to my amp or both? i would rather just do one if possible, but i dont know if the amp can handle the impendance loads
could i run one 12 @6 ohms and drop it down to 3ohms when i bridge it? or would it be better to run it at 12ohms and drop it down to 6 when i bridge it? would the amp be stable at 3 ohms bridged? woud my amp put out enough power at 6 ohms? or should i sell these and get some new subs?
Power Bandwidth 4.5 Hz - 100 kHz
Total Harmonic Distortion 0.02 %
Input Topology Differential
Input Sensitivity 150mv - 12 volts RMS
Input Impedance 10 k Ohms
Load Impedance (stereo) 2 - 8 Ohms
Load Impedance (bridged) 4 - 8 Ohms
Supply Voltage 11 - 15 volts
Damping Factor >500
Slew Rate >50 V/mS
PC2600
150 WRMS x 2 @ 4W per channel
300 WRMS x 2 @ 2W per channel
600 WRMS x 1 @ 4W bridged
and of course this amp is underated.
you should run both 12s with that amp. I have a PC2150 (same amp just earlier model) and run 3 12W3s and they are loud as **** and sound great.
yea but the thing is when you run 3 w3 d6's or 3 w6's you get a 4 ohm load which this amp likes. it was originally hooked up to 3 w3 d6's and i still have them on of the subs just has a big hole in the surround, plus a have a single cab truck so it would be kinda hard to fit those
substance
substance
houston
substance
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
