1x 15" vs. 2x 12" (SPL)
LeXtreme
Hey what would be better for SPL as i want to enter Street A class in dB drag sometime when i get some better soundz. Say with one XXX's/SI Magnum D2 15" or two 12" RE XXX's as rules are different over here, you're allowed 1x 15" in the street A OR 2x 12" so what would give loudest spl in a ported box tuned to lowish freq. ?? What dB ya reckon i could reach say giving 15" 1500wrms wif BX1500D and i'd have another one if went wif 12"s so have 1500w going to each? //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif Or: say a larger amp on the 15" to fully reach potential. Also where can i buy SI Magnum's D2 from, want to look into them more; best priced place also? //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif
EDIT: well say the 2-12's are cerwin vega's 1200W RMS? //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Well whats the point of that then, 2x 12's will always be the way to go?? Thats what i thought just will be a lot more expensive is tha thing. hmmm...
If your going Ported and not Vented, the Ported may be a little bit more versatile in your case.
Since you plan on competing you can have switchable ports. Short ports (high tuned) for SPL, and then when it's time to listen to real music you can switch to some longer ports (lower tuned) for better sound quality, but a little less SPL.
Just my opinion.
Yes that is a very good point, my reason exactly for going ported.. well one of them! Ya just one port (hole) simply change actual port and you're sweet -right on.
Plus one. Works in as small of a box as .7 cubic feet sealed. Also had mine in a 1.75 cubic foot box ported to 36. ****** slammed. Only thing was...
5
249
Let me know if you still have these? Ill take them!
10
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
3K
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
LeXtreme
LeXtreme
New Zealand
LeXtreme
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
