2 subs per chamber? Advantages and dis-advantages
Frogmonster
The Famous Frogmonster
Hay! Thanx for the advice. Im installing 2 Kicker S12L5's into a 90 celica. I've got my max/min air space to work with and a basic box desighn. Small and seald. This guy has a single 1400 R.M.S. chanel to run them. I was wondering...
What is the advantages or dis-advantages of 2 subs in one seald chamber.
-The subs are ran in parallel off the same channel so there wont be phasing problems.
-I was "told" once you gain an extra 6db by having them in the same chamber. This true?
-Do you simply take the recomended box spec's for 1 and double it or is there a formula.
-Any sq loss?
I havent been able to find any info on this subject so any advice/opinions are apreaciated.
Thax
What is the advantages or dis-advantages of 2 subs in one seald chamber.-The subs are ran in parallel off the same channel so there wont be phasing problems.
Good.
The gain is from the doubling of the cone area and assumes that each speaker is getting the same amount of power as the one was getting. Sharing the airspace has nothing to do with it.
Double the size for a single.
-Any sq loss?
Nope.
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Aw.... You're talking about good ol' Mich.
15
741
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
474
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
Frogmonster
Frogmonster
Canada, B.C.
nosaj070
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
