3 speakers from 2 L&R amp channels...
miscreant
Okay. I have a 2 channel amp, 40watts x2 4ohm, or 60 watts x2 2ohm. L&R channel for my front components. Kenwood 5.25" in door, and tweeter in sail panel, on both sides. One channel on amp is powering Left components, other is powering Right components both at 4ohm through a 2 way crossover network.
I want to add a single center channel. I want to keep my balance control between left and right, but do not mind if the center channel is always left and right, ie. balance to right, center channel still outputting, balance to left, center channel still outputting.
How do I wire this to my amp, but still have the same wattage/volume in all speakers. My amp is stable to 2 ohm.
What happens if I wire both channels to the components and both channels to the single positive and negative on the center channel? Do I end up feeding the center channel twice the wattage?
First, an unprocessed center channel is of the devil. It will tend to wreck your imaging and staging.
Second, to get the same power to all 3 speakers you would need the center channel speaker to be a 16 ohm driver and then bridge the amp in a tri-mode configuration to that speaker and then run the components in stereo. The final load on the amp would be 2.66 ohms per channel.
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
It also lowers the amps efficiency and raises the current draw.
5
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
miscreant
miscreant
Norman OK
helotaxi
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
