4 subs, one mtx class D amp - How to wire
mrmedley123
Just picked up two additional subs. I can't do the math to calculate the ohm load for this application. I've got four 4ohm subs that I'd like to push with my cheap old MTX 4250d. The four subs do match. I've looked over the wiring diagrams on the web, but I'm confused a bit by the internal wiring on the MTX amp that apparently drops the amp down to a 2 ohm load if wiring two 4ohm subs straight to the two channels. Would you advise wiring all four subs in series, split between the two channels, do some sort of parallel/series split, or what. Any advice would be appreciated. Boating season is closing in and I've got to get this straight so the boat will bump just a bit harder.
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Aw.... You're talking about good ol' Mich.
15
741
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
474
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
mrmedley123
mrmedley123
Louisville
ghs_wrestler189
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
