6 X 9 Problems
Brooklynchild07
I have a 85 Ford EXP and it is a hatchback ride. Well, I was wondering if a pair of 6 X 9's would sound best in a small enclosure? Also, where is the cheapest, absoultely cheapest place online to get a pair of 6 X 9's online, because i am taking the 6 X 9's out of my old car to put in the EXP, so i need some really super cheap replacements. (the factory's in that car are blown.)
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
Brooklynchild07
Brooklynchild07
Charleston, SC
kungfoojesus
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
