alpine mrd-m1000
ladiesman8527
The Man
i have a question about the alpine mrd-m1000.....is it too much for two alpine type R 12's......heres some of the specs of the mrd-m1000:
14.4V RMS Power
1000W x 1 [2 Ohm (1%THD)]
500W x 1 [4 Ohm (1%THD)]
12V RMS Power
700W x 1 [2 Ohm (1%THD)]
350W x 1 [4 Ohm (1%THD)]
the Alpine SWR-1221D's and SWR-1241D's have up to 300watts RMS....and a peak of 1000watts....so is the amp to much.....if not, which sub would be the best.....the dual 2ohm or dual 4ohm version?
I'd run that amp for a pair of those subs in a second. I ran 1200 RMS to my 2 type r's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Since the amp is stable to 2 ohms (or so what u posted says) I would take 2 subs that are dual 2 ohm voice coils so you can wire them to 2 ohms.
  • Locked
That MRD is a good series of amps ...i may have some extra accesories if you havent found them
8
3K
my RE SE ($200) graphs (using BBP) lay right on top of the 12w6v2 graphs JLs good stuff but $$$
128
There will definitely be a mechanical noise when you overpower the speakers. That sound will show up long before overheating the coils. Like most...
ladiesman8527
The Man
ladiesman8527
Collierville, TN
BooLeaN
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
