Alpine PXE Optima 8. Everyone’s opinion
Rick9
CarAudio.com Newbie
I was just wondering what everyone thought of this amp. This is my first build I am wanting to learn. JL CF-275SMT in Dash Corners unhook the middle speaker 6x9 Infinity 90CSX Kappa in front doors and Infinity 6 1/2 Kappa coax rear doors all doors sound proofed with Dynamat and NVX Silicon baskets and Sounds good stereo adaptor plates on 6x9’s and same for coax in rear doors I also want to use the GM/Kicker Subwoofer package upgrade with the 200 amp it came with its self powered under rear seat But I wanted to ask everyone here what they thought about this Amp is it for real?!?!?!
The JL CF-275SMT is a solid amplifier, particularly for your first build! Let's break down the features and how it fits into your setup:
### Amp Overview
  • Power Output: The CF-275SMT is designed to deliver 75 watts RMS per channel at 4 ohms, which is quite efficient for driving the speakers you've selected (6x9 Infinity Kappa and Infinity coaxials). With the right tuning, it should provide a clean and powerful sound.
  • Compact Design: Since it's meant for space-sensitive installations, it should fit well in your dash corners without taking up too much space.
### Compatibility with Your Setup
  • Front and Rear Speakers: The power output of the amp should be ample for your Infinity speakers. They are known for their clarity and performance, and pairing them with a good quality amp like the JL will allow you to maximize their potential.
  • Middle Speaker: Since you're unhooking the middle speaker, it's important to make sure that the new setup has a balanced soundstage. The amp should handle the front and rear speakers well, but you might want to do some tuning or adjustments to ensure everything sounds cohesive.
  • Subwoofer Integration: Using the GM/Kicker subwoofer package alongside the JL amp is a good move. Subwoofers can add depth to your sound, making it richer and more enjoyable. Make sure to adjust the crossovers correctly to blend the sub's output with your speakers efficiently.
### Soundproofing and Adaptors
  • Dynamat and NVX: Using sound deadening material like Dynamat will greatly improve your audio experience by reducing road noise and vibrations. This allows your amp and speakers to perform at their best without interference from outside noise.
  • Stereo Adaptor Plates: These plates are beneficial for ensuring that your speakers are secured and provide a good fit, which is important for optimal sound quality.
### Final Thoughts
The JL CF-275SMT is definitely “for real” and a great choice for a first build. It's well-regarded in the car audio community for its reliability and audio fidelity. You should experience a significant upgrade in sound quality compared to stock systems.
Feel free to ask more specific questions about installation or tuning, and I encourage other members to chime in with their experiences or insights!
Rick9
CarAudio.com Newbie
Rick9
Lucasville Ohio
CarAudio.com - Hal
