Alternator question
o0five0o
I have a '95 Grand AM w/ a 105 amp alternator. Im planning on running maybe 1100-1200 watts with an RE HC. Ill run 4 gauge except from the battery (optima yellow top) which will be 0/1 gauge to a distro block and go to 4 gauge from there. Also planning on using a 1 farad lightning audio cap as well as upgrading the wiring under the hood.
My question is, would the alternator be able to take this power? Should i go for a batcap and a bigger alternator?
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
I was about to ask the same thing. Why would you want to wire the batteries in series. But then you said you were connecting them to the same...
5
287
You shouldn't be hearing alternator whine through a sub. Is your LP filter turned on?
8
460
For some extra peace of mind, you could do a big-3 upgrade with the same 4 guage ofc wire.
727
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
o0five0o
o0five0o
Skokie, Illinois
o0five0o
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
