amp @8ohms
substance
houston
i blew out one of my premier dvc 4ohm 10s, (had them wired series and one set of wires were too short, dont ask...) and i cant live without bass, so i hooked the other sub up at 8ohms because my amp doesnt take a 2 ohm load mono. and I thought it would be about half as loud, but i can barely hear it. i had my ppi pc2600 to them @4ohms running ~600watts rms, now @ohms it sounds like 100 maybe even 50, then i hooked up my fosgate 1000a2 to it @8ohms, its a more powerfull amp, but it wasnt even as loud as the PPI, i guess they arent meant to run at 8 ohms...
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Did you integrate the C60 between the OEM radio and OEM amp?
If you can tap before the Bose amp, then you may only need a simple LOC. If you tap after the Bose amp, then you will need a bass restorer/LOC...
substance
substance
houston
substance
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
