amp for 2 12" SE's
those subs are dual 4ohm. on the site it says i would only be able to wire them into a 2ohm load i was wondering if it is possible to wire them into a 1ohm load.
If you get one of em you can get either a 2 or 8 ohm load, if you get 2 SEs you can get a 1 or 4 ohm load. since your getting 2, you can wire them down to 1 ohm.
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Did you integrate the C60 between the OEM radio and OEM amp?
If you can tap before the Bose amp, then you may only need a simple LOC. If you tap after the Bose amp, then you will need a bass restorer/LOC...
JMOCK
JMOCK
Auburn, ME
Moe Lester
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
