Amp for American Bass VFL
  • 3
wafsman
ohio
I don't know if my other post was in the correct forum so I have split my questions up into the proper categories. I have finally found the specs on my subwoofers and am in search of an amplifier to power them. There are two 12's and I have a spending limit of 400, maybe 450 if it was really worth it. Looking forward to hearing your suggestions.
American Bass VFL Series DVC Subwoofers
Common Features:
* Dual 3" 6 Ohm High Temperature Voice Coils.
* 1.4" Wide Multilayer Foam Surround for Better Stable Linear Exclusion.
* Non-Pressed Black Treated Paper Cone.
* Vented Deep Bumped Back Plate
* 180 Ounce Double Stacked Magnet Structure
* Dual Black Mirror-Image Spiders For Linear Stability.
* Sleeved High Power Tinsel Lead Wires to resist Lead breakage.
* Blackened Motor Parts for Superior Heat Dissipation & Long Life
* Hyper extended Pole Piece Increases Accuracy, raises Induction.
* Deep Bumped Back Plate to Increase Power Handling.
* Uni-Rubber Gasket for Airtight Seal in Mounting.
#VFL12 - 12" 1500 Watt Woofer
* 750 Watts RMS
* 180 Ounce Magnet
* Efficiency: 91.75dB
I have a post in the enclosure section asking about specifics, but I know it will be a ported enclosure. Electrical, I will have 0 gauge power and ground coming from the battery and a 5 farad cap. Yes, it's for a daily driver.
As far as the enclosure goes they are 1.75ft3 - 3.5ft3 ea net volume , amplifier wise you are going to wind up with a 1.5ohm DCR with a pair , I would maybe try 2 VFL100.1 or VFL150.1 strapped to the pair or a nice 3K
try contacting Bob @ American Bass about the enclosure recommend for your vehicle
What other electrical upgrades would be needed? I was thinking of a Kinetik HC1800 to replace the battery. Is there any other amps that would work in case I can't find the American Bass amps?
I bought it from Amazon last year.. i have had plenty of bad products from amazon :(
15
269
I had this same amp installed about 9 months ago with no issues whatsoever which make all this odd
10
867
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
What amp/make and model and what sub/make and model. What HU being used?
393
wafsman
wafsman
ohio
wafsman
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
