i have 8ga wire running 1200wrms the 8ga go from front to back i wont to run 1/0 all the way back will this make my amp more eff.and i know this is a knob ? so dont burn me to bad
Trying to run 1200 watts through 8 gauge just doesn't cut the mustard..//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Hell, my personal opinion...I'd be weary of running 1200 watts on 4 gauge..
Just run 1/0 gauge to start with even if you plan on doing a small system, and IF you ever need to upgrade equipment, your wire is done.
It'll help the amp run a little better, and once you add the extra battery in the back, you'll notice a sizable gain in output....or at least you should..
