Amp Mounting In 1996 Civic 2DR EX
darrellred
Where and how would be the best place to mount a fosgate 600A4 amp. I am thinking about mounting it in the trunk but do not know what / how to secure the amp. Also how do I remove the door sill trim to run the wires.
I have a sub box that will be facing the back seats from inside the trunk. I don't know if I will have room to mount the amp next to it on the rear of the back seat?????????
Thanks
Darrell
Well an easy place is to pull up the carpet on the back of the seat and mount a peice of wood on there, then put the carpet back over it and stick your amp on there. You could mount it on the floor, just anywhere it won't bounce around or anything. For the door trim just yank. There is a decent amount of room in them, but basically take out the kick panel things run it through them, and get it past the front door, Getting all the paneling off in the back is sort of a *****. I have directiosn lying around here somewhere tellin how, if i find em i'll let you know.
I have a sub box I was going to put in the trunk and face the back seat. Do you still think mounting the amp next to the box on the rear of the back seat is a good idea?
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Did you integrate the C60 between the OEM radio and OEM amp?
If you can tap before the Bose amp, then you may only need a simple LOC. If you tap after the Bose amp, then you will need a bass restorer/LOC...
darrellred
darrellred
arlington, Tx
darrellred
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
