k ill check that out.You most likely are shorting to ground or your ground is coming loose, since it worked before. Check your amps ground, make sure it is still good and tight, both at the amp and grounding locations.
Sounds like ground issue to me man.one more thing to addi forgot i did this, but the remote bass level control was unplugged, so i plugged it in and turned it up a bit and the subs shut down
unplugged it and protect mode came off, but still subs dont work
tried plugging it in one more time and got a lil feedback from the subs for about half a second.
any ideas?
I completely understand! But even stuff I have done has come loose!had it installed by a friend, but he knows his ****, i only know a little bit
