AMP suggestions - sep'r8 real from hype -
Techspert
I was told by an installer shop that McIntosh amps are top of the line and extremely clean; however, they also mentioned that McIntosh overrates their power ratings and will not give you the kick or dynamics of amps such as JL or the new MB Quarts-type amps.
Is there any truth to this?
I'm looking at possibly purchasing a McIntosh MC4000M 6-channel locally that produces 4x100 and 2x300 watts. I'm gonna do MB Quarts components and 1 13"JL W7 ported, OR 2 JL W6's in a sealed enclosure in an '02 Range Rover. I'm hoping the McIntosh will be appropriate and a perfect mate for this setup.
They're suggesting that their in-house JL 450.5 and JL 1000.1 would be a better match.
I'm not worried about the money spent of the McIntosh in comparison to the JL stuff, but I do want the best sound.
Your comments and opinions are appreciated.
Thanx.
Thanx.
it is NOT powerful enough to push a 13w7 OR 12W7 OR 10 W7
Not enough???
It has 4x100 for highs and 2x300 for the subs...are you sure?
I would think the 2x300 could be bridged or something to get at least double the power.
pls don't spend that kinda money on an amp and have it not be stable....
u need at least 500 watts for the 10
need 750 at least for the 12
and need at least 1k for the 13
invest in something else........ go w/differne tsubs if u have to
mtx9512
mtx9512
The MC4000m is stable down to 2-ohms. I would consider trying another sub type of the w7 requirements were a little too high. The requirements on the w6's should be in my ballpark.
i disagree...usually when u bridge an amp the min ohm load is 4ohms
True. And usually a sub (or any speaker for that matter) will not present its nominal impedance in a real world application. It will be something higher and will vary depending on frequency and enclosure.
I agree that there is no reason in the world to spend that much on that amp, stable or not.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
Hi guys, I’m John. Been out of car audio for probably 15 years or so. I built a couple boxes back in the day and was definitely a bass head but...
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Techspert
Techspert
Atlanta, GA
helotaxi
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
