I will post my setup below, but the fact is my amp went out and I'm feeling very low because it. I've tried asking friends but they keep telling me different things. I'm on a low budget $100-150 range. It has to fit in a 2005 Silverado single cab. The amp I had before was only 2inches wide so it wasn't that bad fit pretty well. Had the setup for over 5 years until it gave out today. I just want something the same if not better if I could for the price thanks. Again don't know much about car audio so any help would be helpful thanks.
EDIT: I'd go ask the local shops but I live in a remote area and it would be a 2 hour trip to do so, I'd like to go with some idea of what I would be looking for.
(I bought them for sentimental reasons...)
TWO - JVC CS-WG1000 800-watt 10" Car Subwoofers
Features include:
10-in. subwoofer
800 watts max music power
Glass fiber cone with rubber surround
Aluminum die-cast basket
Aluminum/El wire 4-layer dual voice coil
Rubberized PVC gasket
Black polycotton spider damper
Nickel-plated screw terminals
25-1500Hz frequency response
4 ohms impedance
The people at the shop stuck me with this amp, at the time I was just happy getting one.
NT Power NT1832 Amp
Product Specifications:
Channel: 2
4 Ohm RMS: 120x2
2 Ohm RMS: 150x2
Mono RMS: 300
Max Power: 1200
Dimensions: 350 x 244 x 49 mm
Remote: No
Product Features:
CHROME PLATE TOP
FULL MOSFET POWER SUPPLY
2 OHM STABLE
VARIABLE HI PASS: 50 - 250 HZ
VARIABLE LOW PASS: 50 - 250 HZ
VARIABLE 12dB BASS BOOST @40HZ
FREQUENCY RESPONSE: 10 - 30K HZ
S/N RATIO: 98 dB
T.H.D.: 0.02 %
FULL SELECTABLE CROSSOVER
4 GAUGE POWER/GROUND CONNECTION
CIRCUIT OVERLOAD PROTECTION
INPUT SENSITIVITY CONTROL
SOFT TURN “ON” SWITCH
Features include:
10-in. subwoofer
4 ohms impedance
NT Power NT1832 Amp
Channel: 2
4 Ohm RMS: 120x2
2 Ohm RMS: 150x2
Mono RMS: 300
Max Power: 1200
Remote: No
Product Features:
CHROME PLATE TOP
2 OHM STABLE
S/N RATIO: 98 dB
T.H.D.: 0.02 %
