I will be purchasing a 0/1 gauge wire kit for 2 amplifers, Diamond D7401 (800RMS at 2 Ohms) and Diamond D7152 (2 X 150 RMS)
The wiring will be the following 4 gauge into a distribution block into a single 0/1 gauge wire. My intention is to use a 150 watt fuse near the battery with an inline fuse holder.
My questions are as follows:
Do I need fuses on the 4 gauge line prior to the distribution block?
When wiring the ground, what size wire, 0/1 or 4?
When wiring the ground should I run the wire all the way to the battery or ground near the amplifier?
I have read the fuses are used to protect the wire from catching on fire. Do I only need to fuse the wire for the maximum output or RMS of the amp?
