Amp Wiring
Chazbo
N/A
I have 4 gauge wiring going to the back of the car to a distro block putting out 2 8 gauge wires.
The problem is that one amp I'm looking at running is a Profile CA640(for comps and rear) and it requires 4 gauge power and ground. The other amp is a Crossfire 100.2 tek(sub) which has run fine off of 8
Will it be okay to run the 8 gauge to the Profile since it comes off of a 4 gauge or do I need to run seperate wire. Both amps are rated as 2 x 25 amp fuses.
I'm thinking it'll be okay but I'm just looking for a little re-insurance.
Any tips or suggestions appreciated!
One other question I had was when I'm wiring up the comps I was going to run the speaker wire along the same general path that the power is following on the one side and the RCA's and remote on the other. Are either of these going to cause any interference???????
Thanks!!!!
with a 2x25 amp fuse? That seems more like an 8gauge amp to me...but that's just me.
I think the general method is to do power on one side, rcas on the other, and speaker wire doesn't matter what side. remote I think you can do whichever side you want, but I had mine with my power wire since I consider that power.
on some kits the remote is attached to the RCAs so it just stays with them, and as long as you keep the 8ga fairly short, you shouldnt have any problem
power wire emits alot of EMI (electromagnetic interference), because of this you should RCA's on the other side because the RCA's would pick up the signal and send it to the amp as sound, and it will be reproduced as ugly, ugly sound....
as for remote, it doesnt really matter, whichever side your doing and the remotre wire is out, just do it lol..
as for running wires, DO IT. power wire look ugly out in the open. just unscrew your kick panels and door sill, then tuck the wire underneath your carpet, and put the panels and sills back on.. its VERY easy
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
647
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
6
Chazbo
Chazbo
N/A
brandonloserkid
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
