Amplifier Switch?
venoxcide
US
Hello all,
This may be bit of a weird question.
I was walking around Best Buy the other day and noticed they have little switches to turn their amplifiers on display on and off.
You can play music with the amplifier off for the "regular" sound then press the button, and the amp kicks on and the music gets amplified (without stopping).
I was wondering how is this achieved because AFAIK if the amplifier is off, no sound gets passed through, or perhaps I am wrong?
I was interested since I frequently listen to music in my car with the ignition off, and for that I probably don't need my amplifier on draining my battery pushing my speakers and sub as it's a very low volume regardless.
Thanks!
You'll need to run at least one set of speakers off deck power. Then a toggle switch on the remote wires as far as the deck running without the key on. You'll need to run the decks acc wire (red) to a Constance power source
Ok so, if I do that, then what I'm understanding is that when the amp is switched off, the two speakers hooked up to deck power will still play right?
I have two aftermarket speakers in my doors that will be amped. The two rear speakers won't be amped (yet, since they are factory).
Is there anyway to have the speakers that are connected to the amplifier still play if the amp is turned off, I guess is what I'm really asking.
Like I said, I've seen it in the stores where you can switch the amp on and off in real time and the speakers still play, but when I asked the Geek Squad guy how that was done he didn't have any clue.
they use relays. 5-pin relays have a normally closed position and a normally open position. relays can be controlled as a group.
i do this on boats so there is a low power mode where amps are powered by the head unit and then a high power mode where the speakers are powered by amplifiers. a flip of a switch can energize a bank of relays to switch state, turn amplifiers on/off, etc.
let me know if you need more info and have a specific project.
Hmm okay. I haven't heard of relays before.
I've been looking up a bit on them and it seems quite confusing, but I'm sure it's not once you understand how it works.
So, yeah essentially what I'd like to do is wire up my system with a accessible switch near the steering wheel so I can trigger the amplifier on/off.
When on, everything would function as normal, but if switched off, the amp (and sub) would go out but the interior speakers could continue to play using deck power.
I realize that this would be alot easier if I just ran my internal speakers off deck power alone (and just amp the sub) but I really want to get the most out of them so they will all be amped.
Just an update. I ended up replacing the amplifier (eclipse XA1000) with a new-old stock amp of the same specs and it fixed my issue.
7
504
If frequency tailoring circuits cannot be completely bypassed an equalizer will be inserted in the signal path of one (only one and the listener...
13
992
venoxcide
venoxcide
US
keep_hope_alive
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
