basswiigee CarAudio.com Veteran 3,381 2 MICHIGAN May 5, 2013 #1 whats the difference between these fuses? is one preferred over the other? i've always had anl, just came across some cheap midi's should i swap out? or does it just not matter either way?..... Click to read more...
Phoenix Risen 10+ year member OG.... Original Ginger 4,160 1 Dayton/Springfield, Ohio May 5, 2013 #2 unless your competing in meca a fuse is a fuse.
gckless 5,000+ posts CarAudio.com Veteran 5,277 1 San Antonio May 5, 2013 #3 Pretty sure it's just the size. ANL are generally bigger.
