annoying whine when trucks engine is on and off!
  • 4
when my key is turned to on ACC or whatever it is (engine not running but key is on) there is an annoying buzz in all my speakers and my driver side speaker gets little to no actual music, and when car is on theres a high pitched whine along with that buzz that matches the trucks rpm, and i can even hear when i turn my turn signal on in my speakers, and my driver spearker cuts in and out. im freaking losing my mind here. please help.
ill check the amp ground, i know its screwed into the floor board somewhere, not a factory radio, nothing in this truck is factory. i have no clue where my battery ground is, unless thats the same as the amp ground
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
3K
I feel like it may be the alternator. The physical unit has the exact same whine. It's pretty new, but I'm also not sure if this is normal or not...
8
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
3K
89sasha10
89sasha10
East Lansing, MI
89sasha10
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
