Quick explanation, I have a 96 Grand Cherokee Laredo with the stock infinity gold amp.(ive replaced speakers and im working on the deck now). If you dont know, the stock amps arent hooked up with RCA's, they have speaker level inputs. The brilliant designer of this system didnt bother with color consistancy for the speaker wires, they change colors 3 times from the head unit to the amp to the speakers.
I need to bypass/cutout the amp as the deck im putting in has more power per channel than the amp(almost twice if my info is right on the amp) but since NONE of the colors match up anywhere its quite difficult.
here's a pic of the wiring harness that plugs into the amp. I believe the larger plug(on the right) is all input as the wires marked with green dots are power and ground. The rest of the wires i have no clue.
http://www.diablo3k.net/forums/index.php?act=Attach&type=post&id=3358
if the smaller plug is all output to the speakers, there's an extra wire. Anyone have a clue what it could be? Or better yet, does anyone know for sure what wire is what(from past experience or whatever)
