Anyone know how warm it has to be to use Bondo Resin?
Pete
Just as the topic says...
I couldn't find it on the can.
It is going to be in the low 30's f. here for the next couple days.
I have the All-purpose Bondo resin from Home Depot.
Is it warm enough for me to use this lately I'm too impatient to wait //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks
-Pete
Usually products that require chemical drying need at least 45 to 55 degrees. You could do it in your living room, but to be honest, bondo is unfamiliar to me so it could be different.
i wouldn't use any fiberglass type product in doors... the fumes are unbelievably strong, nasty stuff that you don't want in your house
With it being that cold I wouldnt do it, but if you must just add tons of hardener. If you have ever worked with resin you know you add more hardener when it's colder.
Take off your skirt guys Bondo/Plastic is not that bad indoors anyways why wouldnt you use a respirator for the fumes? Try using a fixture with a heating lamp and try and stay away from Bondo Brand its the Kraco Stereos of auto body materials...Chromalite works really well, try your local NAPA...I hope this helps
Robb
Hmmmmm. I just used some bondo the other day and i bet it was in the 20s out (it was snowing). I did it i the garage but the fumes were pretty nasty so i opened th big doors and the stuff still dried quik and hard. and it hasnt mysteriosly disinegrated yet, so i say give it a try.
https://www.americanbassusa.com/products/titanium-8-slim-subwoofer Since I've put off my delta 88 build til January or February cause our new...
I'm looking at replacing my 10" Kicker CompR. I have a Kicker 46CXA400.1T that does 400x1@1 ohm and a Fox Acoustics sealed box for a 2016 Ram 1500...
Do you know how much mounting depth you have? Is it a crew cab?
4
538
There is a amp dyno video by big d on youtube of one of these amps.
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
959
Pete
Pete
Minneapolis, MN
AFaceInTheCrowd
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
