Battery/elect. ? confused
amedeuce
:crap:
1,825
CA
Im going to be runnning a Tsunami 1800 amp.
The amp gains will be turned down considerably so not to blow my e10o's.
I know its not the best combo subs and amp but.
Im confused about deep cycle batteries.
I have a 2002 f150. Stock alt is 130amp.
I was thinking of keeping the same alt, just upgrading the battery to either a yellow top or just a bigger reg. battery like a diehard gold.
Upgrading factory wiring to 4 gauge?
I just dont want to have to be conserned about getting stranded with a deep cycle battery or having to jump start it and ruining it. Options, Opinions???
You regular battery should do just fine if your car is running while your system is on. To be honest even if you upgrade to a yellow top, or a deep cycle you could get stranded if you play your system without the car running.
If I do find out I have an over charge problem what can I do to fix that? I’m gonna install my Honda hack back on the radio and it’ll show me the...
6
97
For some extra peace of mind, you could do a big-3 upgrade with the same 4 guage ofc wire.
727
Disconnect the amp for a day or two, then connect it back up. If it stops draining when unplugged then drains again, take it back and have them...
On your van, when you connected the radio, was it a double din or single din? And e the radio sitting in the 2005 Chevy Van, is it nicely fit or...
16
amedeuce
:crap:
amedeuce
CA
pavengmike6
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
