blaupunkt HU?
Nope, it´s actually an CD/MP3/WMA Receiver with CD Changer Controls and very nice one if I might add. Here are the key features:
detachable, fold-down face
MaxTune SQ tuner
12 FM/6 AM presets
plays MP3 and WMA files
displays MP3 text (ID-3 tags)
V-Drive hybrid MOSFET60 internal amp — high-current draw requires direct fused connection to your battery
Bass Engine Pro
Media Xpander™
5-band parametric EQ
XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
CD changer controls for Alpine Ai-NET changers only — add an Alpine changer to your receiver order, and save $25 with Crutchfield's package discount
optional auxiliary input
4-volt front, rear, and subwoofer preamp outputs
wireless remote
clock
27 watts RMS/60 peak x 4 channels
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
why would anyone need a changer if an mp3 cd can hold that many songs? just wondering, also are there alpine hu's that just plays a single disc thru the hu itself?
Dude, this HU plays single CDs (CD-r, CD-rw too) you can also conect a changer to it if you want to and coming soon they´re releasing a couple of HD, 10g and 20g I think, to store mp3s as well. I think that all Alpine HUs play single discs.
But I agree with you, if I can store like 10 regular CDs in a single CD-R using the Mp3 format, why would I need a changer? (that also plays mp3s)
The Blaupunkt BPV 660 is in some cases a better choice to the Alpine 9813. Here's the stats on the BPV 660:
detachable face
ORC V tuner
18 FM/12 AM presets
seek tuning
station and preset scan
rear preamp outputs
loudness
source tone memory
CD changer controls
selectable turn-on volume level
clock
optional wireless remote
27 watts RMS/57.5 peak x 4 channels
CD frequency response 20-20,000 Hz
CD signal-to-noise ratio 98 dB
FM sensitivity 9.1 dBf
Also, costs like 200 dollars less and gives about the same wattage.
thnaks again I could not find this product in europe so I will go with this one ...
10
Lookslike the amplifiers recommended should work just fine with Either Chs 1&2 or 3&4 bridged/mono mode/LPF should work just fine as well as using...
16
4K
unkle11
unkle11
los angeles
rayne8504
Hobib Ali
    Jun 24, 2024
ThxOne
    Jun 22, 2024
